Artic Cat 454 4X4
Old Aug 26, 2011 | 01:21 PM
Big Hill's Avatar
Default Artic Cat 454 4X4
I have an Artic Cat 454 that won't go into gear. Has anyone had this problem. I removed the cover on the right side and the shifter moves all the way to the clutch side.
Old Oct 15, 2011 | 04:56 AM
SHAMROCK4399's Avatar
Hello;
Check the left side,shifter shaft.Under the shaft is a large bolt that goes in to the stop for the high/low range.It has a spring with a ball in it.that also holdes the shifter fork in place,if the spring or ball has came out,the shifter fork won't engage the transmission even though it looks like its working from the right side.If its not engaging on the left side it won't go into gear.I have detailed photo's if you need them.Just write me back
MikeyBoyesq
Nov 27, 2020 02:44 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
Jbird4681
Jun 9, 2015 01:59 AM
Kagey
Feb 25, 2002 01:56 AM
