08 650 brute force 4x4/engine brake probs
Old Sep 3, 2011 | 02:59 PM
diggen deep's Avatar
Default 08 650 brute force 4x4/engine brake probs
engine brake does not make any noise with key on or off? 4x4 just stopped working.belt is good, hours and miles are good also.i don't beat this quad.i need help and i need my brute working.any help would be great. thanks.
Old Sep 6, 2011 | 12:32 PM
Hayashi's Avatar
Is anything flashing on the dash meter when engine is running?
If 2/4WD light flashing back and forth, count the total cycle time for one flash.
Old Sep 10, 2011 | 11:19 AM
Default diggen deep
no, light is not flashing. 4x4 just stopped working
Old Sep 12, 2011 | 03:01 PM
Hayashi's Avatar
Disconnect the 4x4 actuator connector from the main harness. Then apply 12 VDC directly the actuator connector pin, + to red and - to blk, for short time.
If the actuator motor doesn't move or make noise, then it is shot - no good.
If the actuator moves and makes a moving noise, then the problem is else where - maybe the igniter. If you have aftermarket ignition performance part like an ICM, it can burn up the igniter.
Old Sep 13, 2011 | 10:29 AM
ok i will try that.this quad has no aftermarket parts of any kind
Old Sep 14, 2011 | 09:23 AM
Hayashi's Avatar
It can still go bad w/o aftermarket ignition parts...
If igniter went bad, the 4x4 controller (another smaller black box under the seat) doesn't get a signal when you flip the switch from 2wd to 4wd, and it won't engage to 4wd. If that's the case, there is no flashing light on the dash meter and 4x4 actuator motor would work only when you directly apply 12 VDC to it.
Old Sep 25, 2011 | 04:50 PM
ok, first thanks for the help,found the prob it was the fuse. didnt have a tester till yesterday.when i first looked (4 months ago) at fuse,it looked to be good cause it was not blown in hte normal area they blow,but now i have a tester,checked fuse,no good.installed new fuse now engine brake works and 4x4 also.so everything is now working.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Pgbama11
Jan 16, 2016 08:19 AM
Whitelx1
Oct 2, 2015 10:55 PM
Pgbama11
Sep 10, 2015 08:20 AM
