2008 800 efi HO fuel pump issue
Old Sep 7, 2011 | 06:47 AM
jdreck's Avatar
Default 2008 800 efi HO fuel pump issue
Had to replace fuel pump in june of 2010 now 1,000 miles later it is acting like th pump is going out again..If you run it for awhile it runs rough ,cuts out even dies let it sit and cool down and everything is fine till it gets hot again. First time the dealer replaced the pump and sending unit. Is there just a replacement aftermarket pump available and part # since the sending unit should be fine correct?
Old Sep 7, 2011 | 08:34 AM
Check Napa or Autozone for an Airtex pump. What I've been told its # E-8335 OR E8198?? Take your old one in and see if it matches! Hope this helps,others may know for sure! OPT
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
traumajunkie
Jul 5, 2015 03:03 PM
Mikea1978
Jul 4, 2015 12:37 PM
