1999 Kawasaki 220 bayou
Old Sep 7, 2011 | 12:45 PM
wstavisky's Avatar
Default 1999 Kawasaki 220 bayou
How do you remove the rear brake drum?
Old Sep 7, 2011 | 06:17 PM
88moto4's Avatar
remove the wheel take big center nut off. back brake adjuster off and pull it off
Old Sep 7, 2011 | 08:06 PM
wstavisky's Avatar
Default Rear drum will not come off
The rear drum will not come off. It is spline on. Is there a special puller to remove it?
Old Sep 8, 2011 | 10:11 AM
Hayashi's Avatar
No there is no special puller or tool to remove.
Most likely corrosion is holding the drum tight to the hub, especially if this is the first time doing this in a few years or ever. Like the othe guy said, remove the axle nut and adjuster first. And then using a mallet start banging on the outside edge of the drum to loosen up all the corrosion. It will come off sooner or later.
Old Sep 8, 2011 | 03:43 PM
Cat650H12007's Avatar
Agreed. A little WD-40 or better yet PB blast can help. Along with some heat.
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
rockinkgin
Sep 25, 2015 01:52 PM
wendal
Sep 15, 2015 01:50 PM
