1985 Honda 250es Big Red
Old Sep 7, 2011 | 11:31 PM
baitnbobber's Avatar
Default 1985 Honda 250es Big Red
Will not engage in to reverse. Anyone have any good idea on where I should start or trouble shooting techniques. Forward gear work fine. Thanks
Old Sep 8, 2011 | 07:28 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Is your reverse cable adjusted correct? I would check at the right lower engine just behind the right foot peg! there is an small black cover with an small bolt holdong cover on, remove cover then you will see an cable goin to an little arm, that little arm in hooked to the the reverse assit shaft, get someone to put atv in reverse while you watch arm to see if moves than see if you can than put an finger and pull the arm anymore backward than see if reverse comes back! If not get back to us here!!! Good luck!
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Jason Campbell
Sep 7, 2015 02:25 PM
