Lost Keys
Old Sep 13, 2011 | 08:10 PM
Logan2's Avatar
Default Lost Keys
I have 1994 Kawasaki Bayou 300 and I lost the ignition keys, How can I get another key without replaceing the ignition. Thanks Logan
Old Sep 13, 2011 | 08:44 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Key code
Usually you have to have the code that is on the original keys...or may be on the paperwork somewhere (depending upon what paperwork you still have).
Old Sep 14, 2011 | 09:27 AM
Hayashi's Avatar
Kawi does NOT write key code on any paperwork especially on quads. On bikes, there is small metal tab on the key ring sometimes from the factory.
Just get a new set of ignition switch and keys. It's not that expensive I think. Also very easy to replace, just one big plastic nut and 2 wire connector.
Old Sep 14, 2011 | 11:54 AM
Logan2's Avatar
I was trying to take the least expencive way out because I want to sell it. Logan
Old Sep 15, 2011 | 02:07 PM
Hayashi's Avatar
The cheapest way would be to rig up with one toggle switch and one momentary switch from Radio Shack and do your own wiring. But then anyone could drive it off if they know about it.
Old Sep 15, 2011 | 02:10 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
All the more reason to properly replace the ign. it's easy & cheap. Plus, not too many people will buy an atv with a busted ign... I know I never would.
First thing I'd think is "where the hell did this atv come from "
Old Sep 18, 2011 | 04:58 PM
Logan2's Avatar
Now that I found the key , when i shut the engine down the carb leaks gas out the rubber hose on the bottom of the carb. i have to shut the fuel tank pet **** off to stop it. What could be the problem. need to fix to sell. thanks Logan
Old Sep 18, 2011 | 06:29 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
your needle is stuck in the float bowl- sometimes just tapping the bowl with a screwdriver handle will loosen it up- but it really needs to be cleaned properly.
Old Sep 18, 2011 | 06:34 PM
Logan2's Avatar
Thank You
95wolv
Sep 27, 2024 12:00 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
