Carb
Old Sep 19, 2011 | 03:32 PM
Logan2's Avatar
Cool Carb
How do I remove the carb to put a needle in it or can I put it in with the carb on. 1995 Kawasaki Bayou 300 4x2 ATV. Thanks Logan
Old Sep 20, 2011 | 09:26 AM
Hayashi's Avatar
Probably you can do it on the quad if you can access to the 4 screws that hold the cover for the slide & needle. However, tt's better to remove the carb from the quad and do it right. In that way you can clean the inside as well.
Old Sep 23, 2011 | 09:18 AM
Logan2's Avatar
How do you remove the choke cable from the carb and the throttle cable bracket screw I can not get loose., I have everthing else off. 1995 Kawasaki bayou 300. Thanks Logan
Old Sep 25, 2011 | 06:42 PM
Logan2's Avatar
What gap do I set the spark plug for a Kawasaki Bayou 300. Thanks I got the carb fixed Thanks logan
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
