Electrical help with 1999 Foreman ES
Old Oct 5, 2011 | 04:50 PM
wagnerdw's Avatar
Default Electrical help with 1999 Foreman ES
I just installed a new winch on my 1999 Foreman ES. I have the winch working, but in the process I must have shorted something. When I turn the switch on I see nothing on the display.. and no starter. I checked all the 3 fuse areas and could see nothing wrong. I should also mention that when I first tested the switch to see if the display work, it worked fine. Then I failed to turn the switch off and began doing final connections to battery etc. The manual specifically says the switch should be turned off when connecting/disconnecting battery. My foolish mistake. I expect that messed something up.. again checked fuses and didn't see anything wrong there. Any advice would really be appreciated. thanks in advance. Dave
Old Oct 6, 2011 | 06:47 PM
wagnerdw's Avatar
Default Resolved
Found a loose wire.. small positive wire that went in beside the battery cable. what a pain.. but happy to have it resolved. thanks for listening.
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
rockinkgin
Sep 25, 2015 01:52 PM
