87 250x how does the rearend come apart?
Old Oct 10, 2011 | 07:28 PM
derbyboy25's Avatar
Default 87 250x how does the rearend come apart?
ok guys i am trying to change the rearend bearings on my 250x i am lost on how the rear comes apart to change the bearings. i am thinking that the two nuts on the right side of the rear come out/off and the rear slids apart. but when i lossened the nut it went alittle ways then got real hard. please and thank you for all help.
Old Oct 11, 2011 | 06:53 AM
budedm's Avatar
It should come off. Maybe the threads are bunged up. Should be a nut on the right and an allen on the left.
Old Oct 11, 2011 | 09:12 AM
derbyboy25's Avatar
it has two nuts on the right side but i am not real sure what the allen head you are referring to. it looks to me like the two buts come off and the rear end splits into two pieces. thanks and please make it to where i understand about the allen head lol
Old Oct 11, 2011 | 10:43 AM
budedm's Avatar
I thought you were talking about the swingarm. You must be talking about the axle. One is a locknut. Separate the two nuts from each other and then there is a circlip on the axle that has to come off.
Old Oct 11, 2011 | 06:43 PM
95wolv's Avatar
Yup, have to loosen it enough to expose the circlip, then remove it. I swapped out an axle on my 300ex before selling it, and found the axle would not go through the housing, turns out there was a slight burr on the groove for the circlip, just had to smooth it with a file, and then hit the end of the axle with a hammer, using a block of wood on the end of the axle to protect the threads from damage.
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
ScoobyDFW
Aug 4, 2000 11:03 AM
owen350x
Jul 30, 2000 01:58 AM
YellaTerra
Mar 30, 2000 04:38 PM
