05 700 efi overheats / fan will not run
new here and looking for some help. my 05 700 runs hot cause the fan motor won't come on. put 12v to fan motor and it runs fine. replaced temp sensor and checked wiring and fuses. traced fan wires to ecm. replace ecm or look for something else?
Have you checked the fuses,plus has a thermal circuit breaker that could be a problem?? Circuit breaker should be up the harness from the fuse block! Also have found shorts in the fuse block wiring on a couple machines. Plus welcome to the forum! OPT
sorry, pdm? I have checked everything involving the wiring and fuses/breakers associated with the fan. I finally traced a gnd wire and a hot/control wire to the ecm. before I spent the money for one I was checking to see if someone had this problem and if I missed something.
