Need some advice
Old Oct 24, 2011 | 09:38 PM
mojavemen's Avatar
Default Need some advice
I have a 05 300 Trx sport
It starts fine but once the throttle is applied more than 1/4
The bike sputters and wants to turn off if I keep the throttle 100%
Any ideas would be appreciated .
Old Oct 27, 2011 | 10:10 AM
fulk112's Avatar
its a carb issue... take it apart and clean it good and put it back together, you might condier a rebuild kit..
Old Oct 30, 2011 | 07:46 PM
jgar's Avatar
You have a clogged jet, clean the carb.
Old Nov 2, 2011 | 07:23 PM
TacticalRedneckofKentucky's Avatar
i rode around on my 300ex like that thought one day and i looked down and my choke was on
Old Nov 2, 2011 | 08:40 PM
quadtrx400ex's Avatar
yep ^^ clean the carbs
Old Nov 3, 2011 | 03:13 PM
Fire3096's Avatar
It may be the timming? Try carb first....Good Luck!
Old Nov 8, 2011 | 01:01 PM
rob1922nys's Avatar
check ur timing pull the timing plug out the case line the t up with the notch in the case on the cam gear there are three marks two lines and a dot the dot points up and the two lines should sit level with the head if its in time check your carb again i have one doing the exact same thing thought it was jets cleaned them didn't change a thing. on the side of your bowl on the carb there should be a primer try pushing that while your trying to go if it runs while you pump it you got a carb prob rebuild it if it doesn't i would check my timing anyway hope i helped ya now everyone knows what i got goin on any suggestions
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
