92 honda fourtrax 300
Old Oct 30, 2011 | 11:13 PM
narkedout's Avatar
Default 92 honda fourtrax 300
i have a Honda 300 new wiring harness new cdi box new plug it will start and idle fine but u give it gas it misses and back fires also if you hook up the battery when running it will not idle all it does is back fire you you turn on the head lights it will just die im lost at this point checked every thing in the manual and its all in range it seems like it jumped timing but then also seem electrical any help please
Old Nov 8, 2011 | 12:48 PM
rob1922nys's Avatar
check ur timng couldn't hurt check for spark and check to see if ur flywheel is rusted might not be gettn good fire out the stater coil
Old Nov 13, 2011 | 09:04 PM
Oldsman67330's Avatar
Odd that hooking up a battery will kill it, maybe the voltage regulator is fried?
Old Nov 17, 2011 | 08:29 PM
narkedout's Avatar
I checked that it seemed to check out what the manuel said im goin to try and find a good voltage reg around and see I hope it only cuts out at higher rpms it idles fine
Old Nov 20, 2011 | 08:02 PM
mudflying's Avatar
Default honda 300 fourtrax
the wires on the back of the key switch broke off an i want to put a new switch in but i don't know what wires are what
Old Nov 21, 2011 | 11:28 AM
budedm's Avatar
I would say it's the wrong wiring harness, wrong CDI, or something is hooked up wrong. It's probably something simple like that.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
