axle extenders
Old Oct 31, 2011 | 04:23 PM
450r killer's Avatar
Default axle extenders
do axle extenders on sport quads break to easy or are they pretty tough
and yes i do race i just dont want too drop 300 for a whole new axle
Old Oct 31, 2011 | 08:00 PM
95wolv's Avatar
Do you mean wheel spacers? while a cheap way to gain width and handling on your quad, depending on the strength of the stock axle, if you go too wide, you run the risk of bending the axle if you do a lot of jumping , as you would in racing. I put 1" spacers on my son's 300 ex rear axle, it was good for years of trail riding, then he started doing jumps over field approaches in the ditch, ended up bending the axle right after the hub, the spacers put the load of the wheel farther out on the axle end, increasing the force applied to the end of the axle, kind of like using a crowbar to help you pull something apart,which can cause the axle to bend more easily. If you plan to race a lot, spring for the axle now, or you will most likely be pulling a bent stocker later.
Old Nov 1, 2011 | 12:24 AM
HEBTEXAS's Avatar
can u please help me! i wanted to ask a question about wheels and tires but have no clue who to post a new thread. i dont see any botton for it????? i would like the spacers and those would work to make them wider but if ur jumping im not sure i would go that route.
Old Nov 1, 2011 | 12:44 AM
95wolv's Avatar
To start your own thread, go to the top of the page, click on "ATVconnection.com ATV Enthusiast Community", then go to "Drivetrain Suspension and Tires", you will see "Forum Tools" in blue print on the top of that page, click on the down pointer next to it, a menu will come up, one of those will be New Thread, click on that, and you are ready to go.
Old Nov 2, 2011 | 04:02 PM
thank you sir i will not be puttin wheel spacers on now
Old Nov 2, 2011 | 07:18 PM
TacticalRedneckofKentucky's Avatar
they have an adjustable axle on rockymountainatvmc.com i think for around $130 gaurenteed to hold up. Supposed to work real good to i thinik
Old Nov 3, 2011 | 03:58 PM
thank you sir
haha massey ferguson!!
bigred20653
Oct 2, 2015 10:05 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
