420ES with really strange reverse shift problem
Old Nov 2, 2011 | 04:30 AM
legoland's Avatar
Default 420ES with really strange reverse shift problem
Hi,
We've got a Honda TRX 420FE (ES) thats acting very strange.
The electric shift works perfect. However when put in reverse, the display shows a constant "-", not the usual "R". The "-" is not flashing. You can go in reverse and release it to Neutral all right with no problems.
However, if the ATV is put into Reverse and you turn off the the ignition then the gear shift locks up. The display still shows a constant "-" but the ATV is stuck in Reverse. There is no sound of the gearbox trying to shift into neutral, in fact there is no response at all when hitting the up arrow or down arrow. The only way to shift out of Reverse is to use the manual tool for shifting it into Neutral.
You can put the ATV into all gears including Reverse, back and forth as long as the engine is running or the ignition is on without the engine running. But if you turn the ignition off while in Reverse, it is stuck.
There are no error codes.
Any ideas? We have spent quite a bit of time on this so far.
Old Nov 5, 2011 | 12:54 PM
legoland's Avatar
Fixed the problem
Turned out that someone had changed the wiring in one of the connectors...
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
