400ex problema
Old Nov 11, 2011 | 03:43 PM
Nickjblack89's Avatar
Default 400ex problema
03 400ex hot cam stage one k&n air filter t-4 slip-on I tried rejetting the carb I went from stock to 155! Ran fine but I was think it was alil lean soo I changed it too 170 and change the oil to mobile 1 15/50 now at almost full throttle it backfires and spits any ideas ??? I live in fAyettevile nc 240ft sea level!! Maybe change to some better octane fuel ??
Old Nov 11, 2011 | 04:37 PM
jgar's Avatar
Try a 158 and 160, with a 42 pilot, fuel adjustment screw 2.5 turns out from seated. I would think a 170 would be way to rich. A 170 is where I would start with a modded 416. Do you do the plug chops, if so what does it look like?
Old Nov 11, 2011 | 05:35 PM
I'll try it out tomorrow also the valve cover is leaking oil out and the drain plug is stripped all from the pervious owner any idea on how to fix ??
Old Nov 11, 2011 | 07:07 PM
jgar's Avatar
You can get a new gasket for the valve cover and find out why its leaking. The drian plug, tap and replace?
Old Nov 11, 2011 | 08:13 PM
Stupid question should I put rtv on the gasket??
Old Nov 12, 2011 | 08:42 AM
bartmann's Avatar
Banned
I got rid of the gasket and use yama bond. clean both surfaces real good and wipe with brake clean .. thin on some yama bond and reset cover. let dry. good for long long time.. I would not use rtv ...
Old Nov 12, 2011 | 02:41 PM
Ok thanks I'll give that a try
Old Jan 8, 2012 | 04:30 PM
knock9876's Avatar
do not do that the metal gasket acts as a shim for the cam,put a thin coat of yamahabond on the gasket and it should not leak
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
