1986 250ES Big Red runs rough
Old Nov 12, 2011 | 10:16 AM
bgelyATV's Avatar
Default 1986 250ES Big Red runs rough
I have a 1986 honda 250ES big red. The motor idles perfect, but when I hit the throttle it cuts out. I have cleaned and rebuilt the Carb (float and float valve, choke valve). Compression is 180 psi with no leakage. I put a new plug in it and I noticed that after just a short period of run time (5 minutes) it is black on the end and smell like gas. Issue has been progressive. For last couple of years I have had to run with choke slighly on. Appears to have good spark but have not checked the timing. Any idea's?
Old Nov 13, 2011 | 08:53 PM
Oldsman67330's Avatar
Have you checked it for vacuum leaks? A cracked intake manifold or boot, bad O rings in the flanges, loose bolts, etc?
SOLOLUCKY
Oct 4, 2024 09:09 PM
Wooodyii2
Nov 16, 2020 07:14 PM
ragewraps
Sep 18, 2015 07:33 AM
wannabe32
Jul 7, 2015 11:30 AM
TJM
Jun 11, 2015 01:28 PM
