Parking brake mounted reverse selector, other options?
Old Nov 16, 2011 | 08:07 AM
LilRedHnda's Avatar
Default Parking brake mounted reverse selector, other options?
Is there any other options on the reverse lock out/selector mechanicism on the parking brake lever? Seems as tho it will get to be a pain in the butt if your plowing and need to back up often?
Old Nov 16, 2011 | 08:20 AM
TLC's Avatar
TLC
Honda's red button reverse set up has to be the most Complicated there is. I plowed a drive way with that set up on my old foreman,what a pain you have to use both hand and and you need reverse 100 times when plowing.
Hope you find the by pass trick. Good Luck.
Old Nov 16, 2011 | 10:00 AM
scootergptx's Avatar
Supersock
Hired Gun!
I have no problem with you asking for help. But if you want to put that link in every post, you'll have a very short lifespan here.
Old Nov 16, 2011 | 08:26 PM
Oldsman67330's Avatar
I took a side plate from an old chain link and drilled one hole out so it the phillips head screw next to the red button would go through the plate and then just put the plate over the button, it holds it down so all I need to do to go into reverse is pull the brake lever...now the rear drum brake getting water in it and freezing after I park the machine is a whole other ball game...the brake shoes are on the bench, and I upgraded the front to disc brakes.
Old Nov 16, 2011 | 11:37 PM
LilRedHnda's Avatar
what link?
Old Nov 17, 2011 | 03:30 PM
Supersock
Hired Gun!
Originally Posted by LilRedHnda
what link?
Old Nov 18, 2011 | 06:43 AM
It's just the side plate off of an old 41 drive chain, I just took my die grinder and ground the pins off and popped the side plate off of the chain link an recycled it....got me a green honda I guess.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
Schneider
Jul 24, 2015 05:05 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
bikedad3
Jul 2, 2015 02:15 AM
