idle bad/pops back
Old Nov 20, 2011 | 02:04 PM
ghostrider1545's Avatar
Default idle bad/pops back
i have a honda foreman 500 4x4 2006. it does not idle and when throtle is released it pops bad. i put in new plug, drained and refilled gas. what do i do?
Old Nov 21, 2011 | 09:06 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Air / fuel mixture screw. Back it out a couple of turns at a time until it stops popping.
Old Dec 3, 2011 | 10:06 AM
TacticalRedneckofKentucky's Avatar
Lightbulb
Are your exhaust bolts nice and tight?
Old Dec 3, 2011 | 12:24 PM
95wolv's Avatar
Could be time for a carb cleaning, the pilot jet, which controls fuel flow for idling and low speed throttle, is extremely tiny and easily plugged with gunk or dirt. My son's old 300ex would not idle, but would run if you held the throttle open, pulled carb and found the pilot jammed full, had to use a strand of wire from a wire brush to open it up, ran like a champ after that. Air fuel mix screw should be at about 2-3 turns out from gently seated (dont crank it down hard) any more than 4 turns and either you need a bigger pilot jet, or you have a plugged passage in the carb. Unless you have modified the air box, increased air flow will require more fuel.
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
