ATV pulls to the left
Old Nov 25, 2011 | 06:57 PM
wonl2's Avatar
Default ATV pulls to the left
I recently bought a 2001 TRX250 recon. The atv pulls to the left when traveling on hard surfaces. Doesn't seem to pull much off road. I checked the tire pressure. Is there a way to s=check the "front end alignment? Any other ideas???
Phil
Old Nov 26, 2011 | 05:47 AM
Oldsman67330's Avatar
The manuals have a procedure for checking the alignment, I don't have it in front of me, but if you put the atv on a flat surface, bars in the straight ahead position, lay a straightedge lenghthwise along the wheels from front to back, you should see the same amount of toe in on both sides. If you use a tape measure on the front wheels from the same point on each wheel at both the front and back of the axle you can set the toe in, it's something like 5/16"
with the problems Honda had with the drum brakes, it could be a brake dragging as well.
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
akbrewcrew
Aug 9, 2015 10:54 PM
cornermike
Jul 30, 2015 06:37 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
