00 Recon pull start
Old Nov 26, 2011 | 07:27 PM
buds87gn's Avatar
Default 00 Recon pull start
Are there any special procedure when pull starting a 00 recon... I pull on the cord when the ATV is in neutral and it doesn't seem to do anything. Is there something that needs engaged???
Thanks in advance
Old Nov 26, 2011 | 09:11 PM
450r killer's Avatar
i dont think you can pull start it since its an automatic clutch
Old Nov 27, 2011 | 04:56 PM
ddrumman2004's Avatar
I would suspect some problems with recoil starter mechanism itself. Remove the recoil starter and pull the rope to see if ratchet mechanism turns.
It may need to be pulled apart, cleaned and lubed. Just the ratchet part......don't mess with the rope and spring!
When you pull on the rope, you should feel it engage.
Old Nov 27, 2011 | 08:18 PM
buds87gn's Avatar
I thought you should feel something when you pull the rope. I will mess with it tomorrow. Hope it isn't the rope/spring they can be a real PITA!!!
Old Nov 27, 2011 | 10:05 PM
OH you ment pull it with the pull cord LOL i thought you ment like pull it behind somthin and drop the clutch
Old Nov 27, 2011 | 10:21 PM
buds87gn's Avatar
Thats funny! i was wondering what you were talking about... I was thinking to myself " why the heck would a pull cord be installed on a motor that can't be used?" LOL
Old Nov 30, 2011 | 05:10 PM
TacticalRedneckofKentucky's Avatar
you mean the cord pulls real easy, or can you feel it going through compression?
If you can feel the compression id say look for all on switches... and get out the ether...
Old Dec 4, 2011 | 09:35 AM
buds87gn's Avatar
Nope, i pull the cord and its free... No compression at all, motor starts fine with the electric starter. I will try to pull the recoil unit off and see whats not engaging.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Jun 10, 2015 12:45 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
