brute force knock
Old Nov 27, 2011 | 03:54 PM
pooleb's Avatar
Default brute force knock
2005 brute force knock
I have a knock looking for help
I pulled the clutch and the knock is still there so I was thinking crank bearing so i removed the jugs and checked to see if there was any play in the crank bearing. doesn't seem to be any .I did notice one of piston seems to be scuffed on one side. could this be piston slap that i am hearing ? if so what causes piston slap?
thanks Bob
Old Nov 28, 2011 | 09:47 AM
Hayashi's Avatar
Scuffed piston means obviously you sucked in some dirt into the engine. You may not feel the play in the rod bearing by hand but I bet it is worn out. Also, you only checked one. Usually the front one goes out first (because it runs hotter). You need to pull it apart and put in a set of new rod bearing bushings.
Old Nov 28, 2011 | 02:47 PM
pooleb's Avatar
Thanks for the reply
Old Dec 8, 2011 | 09:36 AM
Hayashi's Avatar
Originally Posted by GraceGrace
That the knocking is really loud in the motor.Well i pick it up today and you can only hear the knock on the belt side.you cant hear it on the side that you add the oil on.
Knocking only on the belt side means usually two things:
1. Belt is worn out or irregularly worn or hourglassed. Needs to be replaced.
2. Spider shoes in the drive converter are worn out or too small. Need to be replaced.
One way to check to belt is to remove it, and run the engine to see if the knocking noise is still there or not.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
ylomnstr
Sep 4, 2015 05:02 PM
