Arctic cat 250 4x4
Old Dec 1, 2011 | 06:28 AM
DIXTER1's Avatar
Default Arctic cat 250 4x4
Hey can anyone tell me what is blowing my cdi box once a year im wondering if it could be the volt / reg but this is the 4th won ive had to buy and now having trouble finding one.
Any suggestions besides junk it
Old Dec 18, 2011 | 10:41 AM
Williebee's Avatar
Post Arctic Cat 250 4x4
Welcome to the forum DIXTER1 .
It's possible i'm no pro when it comes electrical issues , however i would check the battery voltage after you've charged it with a float charger 1 to 2amp trickle charge over night ( remove the battery cable's while the battery is charging ) , then using a digital multimeter on the 20 watt setting check the battery voltage , battery should be almost 13 volt's with a full charge ; then reconnect the cables and start engine .
With the engine running the battery voltage should read about 14.6 volt's , you should also check to see if you have short in the wiring by removing the positive cable and touch the cable to positive battery terminal , if there is a short you should see or hear a lite spark when you touch the cable to battery terminal , unless your 250 doesn't have a built in clock like the AC 400's and up there shouldn't have a power drain when youi do this test , the 400's and up have a built in clock that draw's current from the battery even when your ignition switch is in the off position .
If you get a spark you'll need to start removing the plastic's and check for any pinched wire in the wiring harness , Hope this help's !
williebee.........
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
