Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
LT80 Problems.
Old Dec 5, 2011 | 12:18 PM
TheDeadMau5's Avatar
Default LT80 Problems.
1st problem bike smokes like a trooper and bogs down at full throttle. Auto mixer is disconnected and fuel is mixed at 40:1. (i race motocross and used to run my bikes at 40:1 but have no clue if its right for a ATV)
There was a split in the air boot right by the carb and it had sucked a lot of dirt in which i have cleaned out the carb thoroughly and the piston, rings and cylinder are ok remarkably .
2nd problem is the engine wont turn over unless i directly connect the live wire to the red/white wire under the tank, starter motor is fine. This is the starter relay or is there any chance it could be another problem?
Where is the best place to order parts from in the UK?
I can do anything mechanical but electrical is a weak point
Old Dec 6, 2011 | 07:12 AM
LT80's Avatar
LT80 Expert
The start problem could be the start button. Other than the relay, it's the most common problem.
You did a compression test?
Customer Service #1
May 15, 2020 08:46 AM
QuadRiders
Oct 22, 2015 04:13 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
