Kodiak 450 One way bearing
Old Dec 9, 2011 | 10:47 AM
badsanta010's Avatar
Default Kodiak 450 One way bearing
Hi.
Quick question.
I have had my clutch shoes repaired and just reinstalling the clutch set up. In the service manual it states the arrow on the one way bearing should face the clutch housing. This is a bit confusing to which bit it is refering to.
So should his arrow face away from the engine or towards?.
Thanks
Old Dec 9, 2011 | 03:23 PM
EPI Shawn's Avatar
holding the cover in your hand if it has a green dot on it you should not beable to see the dot once the cover is back on if the bearing is on correctly you can rotate the shaft counter clockwise not clock wise
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
YankeeRebel
Oct 6, 2015 06:44 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
