is this noise normal? 2012 550 touring
Old Dec 9, 2011 | 09:32 PM
Specta's Avatar
Default is this noise normal? 2012 550 touring
Black Diamond XTR 1 - YouTube
Its the squeeking noise when I start out and come to a stop.
It's in low range 4-wd and the ADC is on.
Old Dec 10, 2011 | 05:45 AM
My old ears ain't what they used to be but could be just spring squeek as suspension compresses and extends when stopping or first taking off,or even could be a little pad and rotor noise from the water and dirt from the snow? My wife's old Saturn makes the same kinda squeek from the rotor area when it rains,clears up when it dries out. OPT
Old Dec 10, 2011 | 08:10 AM
Specta's Avatar
thanks OPT.
Sounds like possibly the clutch but not sure because it sounds like it comes from the front area instead of towards the rear.
Actually might even be normal.
Old Dec 10, 2011 | 08:19 AM
Think I've seen a video similar to yours when tracks were used and had a similar "squeek" when stopping and taking off! It's been a couple years or so ago I think? OPT
Old Dec 10, 2011 | 08:25 AM
Specta's Avatar
I sure appreciate you taking the time to watch my video and reply.
I see you give tons of great advice that comes from experience.
I'm sure that there are a lot of other members that also appreciate your help.
Thank you.
Old Dec 10, 2011 | 09:46 AM
sportsman rocks 's Avatar
just make shear you keep the suspension well greased and no heavy loads on the drive belt for 200 miles or so. sounds normal for break in.
Old Dec 10, 2011 | 10:24 AM
Specta's Avatar
thank you
I use low range alot and hope to avoid ever having any belt issues. I'm sure I could use high more but why take a chance?
I'm sitting at about 250 miles.
Old Dec 10, 2011 | 10:33 AM
Smile
heavy loads between 7-10 MPH is when i use low gear or plowing snow and mud bogs, other wise I'm in High gear all the time. the XP clutching is way better then the old sportsman.
Old Dec 10, 2011 | 09:57 PM
mtpockets's Avatar
Wow! The Honda Man has converted! LOL!!
Good luck with your new Polaris!
Congratulations!
Squeaks, rattles, noises................it's all part of the fun of owning a Polaris!! LOL!!!
Old Dec 10, 2011 | 10:13 PM
Specta's Avatar
Congratulations!
It was free.
