Wheel stud spinning
Old Dec 10, 2011 | 05:36 PM
bobx2's Avatar
Default Wheel stud spinning
When I removed my wheels to get the new tires put on I had three studs turn when I tried to remove the right rear lug nuts. I replaced the studs but the new ones spin also, so I can't properly torque the lug nuts. Has anyone had this problem before? If so, what is the fix? Thinking about maybe using lock tight on the studs, but don't know if that will hold them tight enough to torque the nuts...
Anybody have any ideas??? Thanks
Old Dec 10, 2011 | 05:53 PM
bobx2's Avatar
I also think the 75 lb/ft of torque listed in the manual is way to much. I broke one stud on the left rear at about 73 lb/ft. Not a fun day changing tires!
Old Dec 10, 2011 | 06:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like for some reason the hub is bad where the studs go into them. there only pressed in, and they are cast alum. i think. locktite won't hold them from spinning for sure and if the hub is alum. then you can't tack weld the studs to the hubs either. if the studs them self aren't stripped then the hub holes must be. that torque rating is for the alum. rims and it's 12 ft lbs for the steel rims if i remember.
Old Dec 10, 2011 | 09:33 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
I stripped one out....ended up having to use a cutoff wheel and cut it off to get wheel off. Then pulled the hub and my neighbor put in a new stud (different size, but I wasn't paying and I wasn't particular!) and tack welded it in. My hub was cast and held without issue! Good luck!
Old Dec 11, 2011 | 11:56 AM
Tonyxp's Avatar
I had this happen on my xp as well. It happened on the rear wheel with the brake rotor so I tool the tig welder out and put a small tack on it to hold it. If they are spinning the hub is probably stripped out. If the hub is wrecked already maybe you could try and drill cross wise into the stud hole and tap it for a set screw. Then grind a flat spot on the stud and put it in the hub and tighten the set screw and see if it holds.
Old Dec 19, 2011 | 11:01 AM
MYWAYOUT's Avatar
I had this happen to an 07 sportsman 500 rear hub. I removed the old stud and welded 4 small beads on the teeth portion of the new wheels stud to make the diameter a little larger and have had no problem since.
Jon
Old Dec 19, 2011 | 01:01 PM
DAMONSQUAD's Avatar
jb weld that bad boy in there!!!!!
Old Dec 19, 2011 | 04:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hope he never wants to take it out ever again lol
Old Dec 24, 2011 | 12:11 PM
jampg's Avatar
Jon
This sounds good....
Old Dec 29, 2011 | 08:25 AM
bobx2's Avatar
Thanks guys. Ended up just buying a new hub and studs. Pretty easy fix and not too expensive.
meddy0388
Sep 9, 2015 06:41 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
