07 hawkeye
Old Dec 21, 2011 | 08:30 PM
2007 hawkeye's Avatar
Default 07 hawkeye
2007 polaris hawkeye backfires eventually boggs down and shuts off i can pull the choke and it will start back up after a few secs. sometimes i can ride it for 15 mins and it does same thing..when it first started doin it i could let it sit for an hr or so and start it up and ride for about 30 mins or lil more then it started doin it again someone told me the coil was prolly getting hot and goin bad so i changed it and the same thing is happening... i had my friend clean the carb and i rode it about an hr and the same thing happened its an 07 i bought it nw and it only has 37 hrs on it i dont know a whole lot about them but ive changed the plug and air filter idk it seems like to low of hrs to be the carb gone bad or something pls helped lol
Old Dec 21, 2011 | 08:35 PM
jlshunter's Avatar
07 hawkeye
the carb may have a carbon build up i have seen this due to the ethanol is gas.. Clean the carb and try that use a fuel stabilizer like XFT... you can order that at xtreme11.goxft.com it works wonders on small engine and other gas engines..it will help with horse power and performance
Old Dec 21, 2011 | 08:47 PM
ihad a friend of mine that works on his 4 wheeler to clean it and it did fine for about an hr or so
Old Dec 21, 2011 | 08:51 PM
also i thought the first valva adjustment came at 100 hrs???
snowolson
Aug 31, 2015 03:51 PM
Sportsman850
Jul 31, 2015 04:25 PM
GreenHawkeye
Jan 1, 2006 07:16 PM
DAHUI
Dec 17, 2005 06:49 PM
