1981 200 honda 3 wheeler runs good wont start
Old Dec 27, 2011 | 02:17 PM
bass hunter's Avatar
Default 1981 200 honda 3 wheeler runs good wont start
I have a 200 atc 1981 honda it runs perfect, but it just wont start about 10 pulls, anybody know what it might be
Thanks,,,
Old Dec 27, 2011 | 02:41 PM
carb was cleaned, also but may need more cleaning , some rust in tank but still runs good, when running,
Old Dec 27, 2011 | 07:53 PM
papa hogg scoot's Avatar
Loved
Community Favorite
May want to check compression! Need to be 90 to 130 pounds!! Sounds like atc may have an tight value an most of the time it is the intake value because of an bad air filter somewhere down the line!!
Old Dec 28, 2011 | 06:52 PM
Default tight valve,
Just wondering how would I check for a tight valve, is on the air intake you say, engine is in good shape for the year, maybe compression, or valve, once it is running it runs perfect!
Thanks,,,
Old Dec 28, 2011 | 06:55 PM
Default 81 honda
Once the bike is running it runs good , but as soon as you shut it off for 10 minutes it is still hard to start even when its warmed up, crazy!
Old Dec 28, 2011 | 07:05 PM
woodsidewarrior's Avatar
It does sound like a tight valve Easy to adjust Let us know if you need help with that, we could walk you through it
Old Dec 29, 2011 | 01:29 AM
Well I have a starting point then Thanks, I not sure on adjusting valve, but i look into it!,,
Old Dec 31, 2011 | 12:43 PM
Took bike out today, sprayed quick start in air cleaner and the bike started first pull!
once it cools down a bit cant start it! crazy
Old Jan 4, 2012 | 01:19 AM
MIsuzukilt230s's Avatar
x2 on the valve adjustment. Do you have a service manual for the trike?
Steven Bandemer
Jun 9, 2015 08:50 PM
Steven Bandemer
May 27, 2015 07:39 PM
RaymondT
May 26, 2015 08:14 PM
ZJnut
Dec 30, 1999 08:33 PM
Joeg
Sep 27, 1999 11:53 AM
