2003 400ex is a Mother to shift
Old Jan 7, 2012 | 02:02 PM
derekcoffman83's Avatar
Default 2003 400ex is a Mother to shift
Ok, here is the deal.....
I have searched high and low for an answer to the question (problem) that I am having with shifting my 400ex. Basically, it won't shift by using my foot, it is way too hard.... I literally have to stop the bike, get off, and shake the **** out of the shifter lever to try and get it into a gear.... Yes, a gear, I don't know what gear that may be because I have to violently shake the lever up and down in order to find any gear.
The shifter lever is NOT bent, nor does it hit the case.
I am not by any stretch of the imagination weak with my foot to shift it.
This sucks.....
I have only found like 2 results on this issue on the all mighty Google but those results were two different causes.
If anyone can help I would greatly appreciate it, because I HATE riding up a big *** hill in 4th gear and getting stuck.......
Old Jan 7, 2012 | 02:55 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Welcome aboard!!! Have you adjusted the shift clutch???
Old Jan 7, 2012 | 03:01 PM
are you referring to the feral on the clutch lever? If so, then yes, that has been adjusted.
Old Jan 7, 2012 | 09:40 PM
Loved
Community Favorite
No the other end of the cable at engine case!!
Old Jan 8, 2012 | 09:40 AM
knock9876's Avatar
sounds like you have a bent shift fork
Old Jan 8, 2012 | 11:55 AM
Doctorturbo's Avatar
GOT BOOST!
^^^^ What he said.
Old Jan 8, 2012 | 02:36 PM
Loved
Community Favorite
Plus one on bent shift fork...I was wanting him the make sure clutch is adjusted correct before going into engine....
Old Jan 8, 2012 | 07:09 PM
can the shift fork be replaced fairly inexpensively? would I just have to remove the cover and plug and play basically? I have a lot of mechanical knowledge, but have never messed with an atv before.
Old Jan 8, 2012 | 07:27 PM
knock9876's Avatar
you will have to disassemble the entire motor down to bare bones the shift forks porbably are fairly cheap,you will have to take the right engine case off
Old Jan 8, 2012 | 07:41 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
"\In other words, not "plug and play", major work.
Clint Russell
Sep 25, 2015 03:20 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
