artic cat youth50 2004
Old Jan 22, 2012 | 12:19 PM
kday06009@att.net's Avatar
Default artic cat youth50 2004
i have a 2004 artic cat 50cc it has compression of 140,it has spark,it is gtetting fuel but will not hit a lick.I've tried startingt fluid.I'v pulled head and piston,they looked good.I put new rings ,head gasket,juggasket,crankshafts seals,and still nothing.The spark is blue but will not light starting fluid.can anyone hep,I'm at a loss.
Old Jan 22, 2012 | 06:50 PM
95wolv's Avatar
Even if you were badly out of time, it should still fire, and maybe even run backwards if the timing was 180 off. Even a bad spark should ignite starting fluid, so that has me scratching my head.Usually on a 2 stroke, hard starting is a low compression problem, but soundls like you have plenty of that as well.
kodiacrunner
Oct 4, 2015 11:52 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
