85 250sx rebuild...help
Old Jan 26, 2012 | 02:54 PM
reddrum's Avatar
Default 85 250sx rebuild...help
I'm trying to rebuild the top end and am stuck right off the start. fly wheel bolt hole cap is soooo seized. got the timing cap off but any suggestions??? also when i remove cam chain tension lifter is there any thing i need to do before removal? just want to make sure. thx for all your help in advance
Old Sep 2, 2020 | 09:39 AM
AjaySummer's Avatar
I know this is an old post, but I recently had the same problem. Just use a punch and hammer, you're going to put a little dent/damage to the outside of the cap, but it is purely aesthetic. This has worked for me every time I have a seized timing cap or flywheel access cap.
As far as the cam chain adjuster goes, nope, just pull it off using the two outside bolts. Just make sure you actually re-adjust the tensioner when reinstalling the top end (after cam chain is fully reinstalled)
Old Dec 30, 2020 | 11:44 PM
Michael Horsford's Avatar
Apply some heat like from a torch lighter if thats all you have & use an impact driver .... Good luck or impact gun.... Heat really does help
dakbee
Dec 30, 2020 11:49 PM
jclark2894
Jul 18, 2012 10:56 PM
rdnred
Apr 30, 2007 09:59 AM
regal007
Aug 3, 2005 12:16 AM
Mr45auto
Jul 4, 2003 02:44 PM
