kaw 650 prarie oil ??
Old Feb 14, 2012 | 10:14 PM
bigcam400's Avatar
Default kaw 650 prarie oil ??
friend fixin to service his new(to him) prairie an was wanting suggestions on oil type an any other thoughts on maintenance needed!! not sure of year model,it is a v-twin an 4x4,thanks for any replys!
Old Feb 16, 2012 | 10:37 AM
Sandman2.0's Avatar
Not sure what weight the owners manual recommends but Shell Rotella 15W40 is about $13.00 a Gallon at Wallyworld. It's JASO MA rated. I use it in all my motorcycles and ATV's.
Old Feb 16, 2012 | 12:52 PM
bigcam400's Avatar
rotella is good oil,...just making sure it dont need wet clutch oil or nuttun exotic...thanks
Old Feb 17, 2012 | 06:51 AM
Sandman2.0's Avatar
No worries with Rotella oil as it is Jaso MA. Most issues were with Energy conserving automotive oils like 5W30.
Old Feb 18, 2012 | 08:27 AM
MrSummit's Avatar
Just curious, but why would a cvt atv require motorcycle rated oil when it has no wet clutch to get messed up by moly content in Starburst type auto oils?
Now, Rotella is a good choice anyway. They also have a T6 5w40 which is rated for MC's and I run it in my Concours.
I've used Automobile 5w30 Mobil 1 in my atv in the winter with no ill effects.
Old Feb 18, 2012 | 09:42 AM
bigcam400's Avatar
it wouldnt less it had a wet clutch,..ant asked fer wet clutch oil,..asked if it needed it,...an fer best oil for this wheeler,..read first post!
Old Feb 20, 2012 | 09:14 AM
Sandman2.0's Avatar
Yes.......good point but you could argue that energy conserving oils and car oils in general contain less ZDDP. That's a whole seperate debate. If you use Rotella your pretty much covered for cheap money. Most likely you could use anything if you change it often enough.
prarie-dog
Dec 5, 2001 11:46 PM
D84
Nov 18, 2001 08:28 PM
wrefer
May 12, 2000 05:06 PM
prarie-dog
Feb 9, 2000 05:53 PM
