1995 bayou 220 carb
Old Feb 20, 2012 | 04:12 PM
iggy03246's Avatar
Angry 1995 bayou 220 carb
I just bought a 220 bayou and had to rebuild the carb. Now when i try to run it, it bogs every time i give it gas. It's like a dead spot. If i feather it it works better but not right. I had to ride back and pretty much let the choke control the speed. Any ideas?? Thanks.
Old Feb 20, 2012 | 05:45 PM
95wolv's Avatar
Sounds like the pilot jet is plugged, that controls your bottom end, does it start hard or barely idle/die a lot? All those point to a gummed up pilot jet. Also, what is your fuel mix screw set to? how many turns out from gently seated? a good starting point is 2 - 2.5 turns out.
Old Feb 20, 2012 | 08:57 PM
john luttrell's Avatar
The slow jet is still partially clogged and will require another visit from you.
Old Feb 21, 2012 | 06:14 AM
iggy03246's Avatar
thanks i'll try to find it and clean it up
Old Feb 21, 2012 | 01:06 PM
95wolv's Avatar
Slow jet---another name for pilot jet
Old Feb 21, 2012 | 01:46 PM
Yep, slow jet, pilot jet, idle jet, all the same.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
rcappie4
Jul 18, 2015 07:51 AM
Sjrpp
Jul 5, 2015 09:04 PM
