08 kfx450 brake/axel problems
Old Feb 21, 2012 | 07:17 PM
08kfx450r's Avatar
Exclamation 08 kfx450 brake/axel problems
therep is movement in the rear axel so when the axel moves up it causes the brake rotor to rub on the brake calibur causing a loud squeaking noise and carving away the rotor it is not the brake pads as they are new not sure what the problem is can anybody help on why this is happening and what i can do to fix it? was supposed to go away this week with this quad and im not sure if i will be able to now please help
Old Mar 15, 2012 | 02:18 PM
Hayashi's Avatar
It sounds like your rear axle bearing is shot/worn out and there is some movement there. You need to check/replace the axle bearing.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
