Valve adjustment video or tutorial? w/ pics?
Old Feb 26, 2012 | 08:55 PM
dog812's Avatar
Default Valve adjustment video or tutorial? w/ pics?
I would like to do the valve adjustment on my quad sportsman 500, i have the service manual but would like to see a tutorial video or pictures first.
Anyone know of one? or want to make one?
Old Feb 27, 2012 | 07:54 AM
Plenty of videos on YouTube,but all you have to do is simply remove the square cam sprocket plate on the right side of the head,pull the recoil slowly(removing spark plug helps) and as the intake valve rocker arms go down and come up look at the cam sprocket and make sure the cam index pin on the sprocket(where it locks to the cam) is straight up center of the head.All valves should be loose. This is TDC and you can check the valves. .006 intake and exhaust. You may or may not even have to touch em unless it's been years since they were checked. Also if it's a 2000 model OR earlier be sure to check for any exhaust cam lobe wear,later models had improved cams. OPT
Old Feb 27, 2012 | 09:18 AM
dog812's Avatar
cool.. yah i watched a few vids about bikes and other machines. It sounds simple enough.
I bought the machine used.. so i dont know what the original owner did or did not do.. it runs great.. but i want the piece of mind.
Ill give it a go.. thanks.
Old Feb 27, 2012 | 09:21 AM
scootergptx's Avatar
Supersock
Hired Gun!
It sounds a lot more daunting than it is.
Once you do it, you'll ask yourself why you worried so much about it.
hondarider1234
Jul 21, 2015 11:53 PM
Aitch
Jul 21, 2015 09:40 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
MNatv89
Jul 7, 2015 11:36 AM
