2011 Sportsman 500 Trans Clunk
Old Mar 21, 2012 | 04:28 PM
shank0668's Avatar
Default 2011 Sportsman 500 Trans Clunk
Have had this atv for 11 hrs and 50 miles and the trans seems to clunk. It is really noticeable when wheel is turned when you get on the gas from a stand still. It will be going into the dealer the 29th.
Just wondering what it could be. Thanks.
Old Mar 21, 2012 | 08:50 PM
Mongrol's Avatar
"Official Site Skeptic"
Welcome to the world of Polaris noises. Annoying? YES. Harmfull? No.
Old Mar 21, 2012 | 09:20 PM
shank0668's Avatar
A clunk I can actually feel is normal?
Old Mar 21, 2012 | 09:21 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
That sound is pretty typical of the 500 trans case. I guess all the 500's that have the trans and rear end together have the clunk. It's a little slack in the gears but nothing to worry about. But if it's under warranty get it checked out to be sure.
Old Mar 21, 2012 | 09:23 PM
Mongrol's Avatar
You should feel my 09 550XP. Brutal, but still works great at 6600 mi.
Old Mar 21, 2012 | 09:49 PM
shank0668's Avatar
Certainly interesting. I'll still take it in but am less concerned now.
Old Mar 21, 2012 | 10:25 PM
Normal as mentioned above to have gear lash on the 500,more noticeable on the larger machines. You have to figure from the motor to the clutches,then to the transmission,then to the drive shafts,there is going to be a little slack. If there wasn't, then something would probably break or wear out even faster! Enjoy your new ride! OPT
Old Mar 22, 2012 | 01:32 PM
TLC's Avatar
TLC
From what I,m reading he says he gets a clunk after he is in gear. I get a clunk when putting it into gear but none applying the the gas after its already in gear.
Old Mar 22, 2012 | 02:25 PM
Some do,some don't! Have has some 500s clunk straight out of the crate when you were in gear taking off, and some were quiet. Almost all the 600s-800s did this,a lot more noticeable.The XPs were downright brutal. I'd like to try one now that they have fixed this. OPT
Old Mar 22, 2012 | 02:55 PM
Mongrol's Avatar
Right you are, OPT. The only Polaris I've had that didn't have any clikx & clunks was my 08 400HO, but never had to repair one of them for that reason.
