Possible causes for FI brute 750 repeated backfiring?
Old Apr 1, 2012 | 10:19 AM
Kernel's Avatar
Default Possible causes for FI brute 750 repeated backfiring?
Went on a mountain trail ride last weekend and it kept backfiring, this was the first time it has done this. There are no engine or exhaust or fuel delivery mods done. Any ideas would be helpful thanks
Old Apr 3, 2012 | 12:15 PM
99scramblerHO's Avatar
Default Leak
It probably only happens when you let off the gas, right? Air is getting sucked into the exhaust (you have a small leak) and that's the problem. I have 2010 Brute with the same thing happening. No matter how I move the clamp and tighten it, I can't get it to seal. My next step is to buy some hight temp gasket material and try to spread a little bit of it at the joint between the pipe for the front cylinder and the muffler.
Use a bottle of soapy water and spray the exhaust while the machine is running. You will see bubbles coming from the spot that it is leaking.
ReconBayou
Oct 31, 2022 05:37 PM
Pgbama11
Jan 16, 2016 08:19 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Pgbama11
Sep 10, 2015 08:20 AM
Brandon400
Sep 7, 2015 12:20 PM
