Spring maintenance
Old Apr 2, 2012 | 11:07 AM
billybob69's Avatar
Default Spring maintenance
Well it's that time of year...so I downloaded the owners manual for my scooter and made a list of things I am going to get done.
Anything else I should do? Is there a service manual I can download? I did some checking but I don't want to give my CC info to buy a service manual if it isn't a legit site but it is hard to tell anymore.
Also...what oil and gear lube do you guys recommend? Plugs? Filters?
Thanks!
Oil & filter change
Tranny fluid change
Gear case front & rear fluid change
Exhaust carbon removal
Throttle cable free play
Spark Plugs replace -type & gap
Air filter
Fuel filter
Old Apr 2, 2012 | 11:41 AM
billybob69's Avatar
I almost forgot. New Drive belt.
Anything else?
Old Apr 2, 2012 | 11:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
grease the fittings if there any. some of those items you mentioned don't require seasonal replacement if they don't need it. just my
Old Apr 2, 2012 | 11:53 AM
billybob69's Avatar
I got this about 2 yrs ago and it has alot of miles and hours on it. I dont trust that the POs kept it up as the machine was well used and abused.
Old Apr 4, 2012 | 11:49 PM
switzomatic's Avatar
I use all popo fluids, ngk plugs, and K&N filter. There are other fluids people have posted instead of oem but always use oem in the front diff!
Old Apr 5, 2012 | 09:24 AM
TLC's Avatar
TLC
I had mine for 5 years now and only changed the plug once(NGK) and belt once(OEM)), I use synthetic chain case oil(any brand) in the tranny once every two years and synthetic 75w gear oil in front diff also once ever two years.(any brand)
-Changed the coolant once.(any brand)
-Change the air filter ever two years(OEM),its not real dusty up here in Norther Ontario.
I change the hub fluids twice a season for all the time it takes(OEM) and change the oil once a year synthetic 0w-40 and filter (Any brand)
I grease the fittings twice a season (Marine grease) I think its more water resistance.
So I only get air filters and Hillary hub drive fluid from a Dealer.
For the newer single Hillary in the front diff I would buy the drive fliud from Polaris if I were you.
Almost forgot,I bought a Polaris OEM battery made by "Yuasa" 5 years ago and it still works great,every impressive for a $65 battery.
Old Apr 5, 2012 | 12:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it doesn't hurt to check the plug and replace if needed, and same w/ the belt. fluids is a given for sure.
Old Apr 5, 2012 | 02:18 PM
TLC's Avatar
TLC
I tried a aftermarket Goodyear "Gator Back" belt once for a day and did not like it,it seemed to slip and even felt like hard plastic vs soft grippy rubber like the Polaris belt which never seems to slip.
Old Apr 6, 2012 | 03:12 AM
I agree on belts. OEM is the only way to go! Can get great prices on ebay. Made the mistake of trying a heavy duty aftermarket belt once. It was the one, and only, time a popo has ever left me hanging on a ride. Shredded after less than 100 miles of riding.
Old Apr 6, 2012 | 06:47 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
imo nothing beats an oem belt for the best results.
dannytas
Sep 26, 2017 06:31 PM
Alex G.
Sep 11, 2017 11:38 PM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
braap123
Sep 7, 2015 12:58 PM
