2002 700 Vtwin no top end
Old Apr 9, 2012 | 09:28 PM
irinman2424's Avatar
Default 2002 700 Vtwin no top end
my nephew has this quad and cant get over 35 mph in high gear with it (sounds almost like he isnt able to get it into High and its running in low gear all the time) can anyone give me some advise to pass on to him on what can be causing this?
Old Apr 9, 2012 | 09:50 PM
found out he just had new plug, oil change and new belt done on it at a shop it was acting up before that
Old Apr 10, 2012 | 11:11 AM
6jeff6's Avatar
If its just revving up (like its in low gear) then look at the shifter and just follow it down its obviously not shifting into high gear..
Old Apr 10, 2012 | 11:14 AM
6jeff6's Avatar
Belt good?
Old Apr 10, 2012 | 02:15 PM
I noticed when I was riding it in Sept last year it was hard getting it into high gear so I had an extensive conversation last night about if its getting into high or not low he said he can only get to about 20 so he knows he is getting into high he just had the belt replaced on it (as stated above) I am thinking its something with the clutches but the mechanic that looked at it when he took it to the shop said the clutches were good I think he needs a 2nd opinion
Old Apr 10, 2012 | 02:52 PM
6jeff6's Avatar
Ya i agree but you would think with the new belt it would atleast smoke if the clutch is bad? But ya i do agree if its in high gear forsure clutch is next..
Old Apr 10, 2012 | 03:14 PM
also he is telling me he has a lot of bobbles of gas going through the overflow tube
Old Apr 10, 2012 | 06:31 PM
6jeff6's Avatar
Maybe fuel pump is going bad or carb needs a kit?
Old Apr 10, 2012 | 09:04 PM
my question is this
if its the carb wont it bogg down when flooding out?
Old Apr 11, 2012 | 06:43 AM
6jeff6's Avatar
Carbs can do some weird things. Is the plug soaked and what color is it? Im also concerned about your cdi not advancing timing when it revs up..
