Honda ATC 110 oil leak problem
Old Apr 11, 2012 | 08:13 PM
ATC_110's Avatar
Exclamation Honda ATC 110 oil leak problem
Hi, I have a 1984 Honda ATC 110. It started leaking oil in front of the drive sprocket on the engine. I took the side cover off and everything looked great so I put a new gasket and seals in and put it back on and it still leaks. So I tried double-gasketing it and putting some Ultra Copper around the gasket and it still leaks. Not as bad and I rode it for 2 hours today and my oil level hasn't gone down but it still drips and the bottom of the engine is wet. Im not sure what to do next. Anybody have any ideas about what's going on?
Old Oct 6, 2012 | 03:23 PM
ccarpen4753's Avatar
Were you ever able to determine where the leak was from, I am having a similiar problem. The suspect oil seal is one that I cant find a replacement
Old Oct 6, 2012 | 05:56 PM
crispy1960's Avatar
There are interchange catalogs for all seals. Let me know the dimensions, O.D. x Bore x width, and I can cross reference a seal for you.
Old Jun 3, 2021 | 01:27 AM
Comewithme_907's Avatar
Default Same issue
Has anyone figured out what's going on I have the same issue
cheappurchase
May 7, 2008 07:26 PM
2000IAWarrior
Jul 8, 2003 07:03 AM
Ward660R
Mar 2, 2002 08:38 AM
Elrancho
Jul 13, 2001 03:21 PM
xcracer250x
Oct 26, 1999 09:12 PM
