Keep Jets Clean?
Old Apr 11, 2012 | 09:13 PM
Garetty's Avatar
Default Keep Jets Clean?
How should I help keep my jets clean on my '08 Outlaw 525? They keep getting clogged and it starts to run hot. The exhasut got cherry red at first.
Should I get a better air filter? It's pretty dusty where I ride, and it has an aftermarket filter from when we bought it. I'm also thinking about turning the gas off and let it run until it runs out of gas.
Old Apr 11, 2012 | 09:22 PM
SOLOLUCKY's Avatar
I run a mix of Sea Foam about every other tank of fuel,,,Sea Foam is the ONLY fuel cleaner That I use that I KNOW works...not to get into a big debate over fuel system cleaners but it works..others might too but this stuff works and if it is in fact a dissolvable dirt that stuff will clean it out.
Not sure why you are overheating , but too lean a mixture will surely overheat yer machine.
Old Apr 11, 2012 | 09:28 PM
Jaster94's Avatar
your fuel filter might need to be changed out. you may want to see if you can find a different micron size than a standard fuel filter. just a thought.
Old Apr 12, 2012 | 06:53 AM
SOLOLUCKY's Avatar
The fuel filter would surely make it run lean if it is starving for fuel..good advice !
Old Apr 12, 2012 | 07:06 AM
scootergptx's Avatar
Supersock
Hired Gun!
Might also want to take the tank off and give it a good cleaning to get any stuff out of it that may be clogging the jets.
Like the others posted, fuel filter, better air filter and about every 3 or 4 tanks, run some seafoam through it.
Old Apr 12, 2012 | 07:07 AM
6jeff6's Avatar
I use stp gas treatment every 5 tanks or so on my two strokes and everything runs clean. I also run premium gas so that damn ethanol doesn't gum stuff up..
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Reactant
Jul 16, 2015 10:29 PM
