Battery terminal under Headlight pod
Old Apr 16, 2012 | 10:47 AM
Padraic's Avatar
Default Battery terminal under Headlight pod
Can any one tell me what the 9 volt battery terminal under the headlight pod on my 2007 Polaris 800EFI is?
Thanks
Old Apr 16, 2012 | 05:41 PM
95wolv's Avatar
could it possibly be to hold ECU memory if you are removing/ disconnecting the battery,or to hold any changeable settings on your pod display? I know in cars, they make a 9v battery adaptor so you dont lose your radio settings and other stuff when disconnecting the battery for service or replacement. I'm not a Polaris guy, so I am just guessing !! maybe OPT will chime in soon with the real answer !!
Old Apr 16, 2012 | 06:14 PM
The 9 volt battery connection is used when you hook the atv up to the Digital Wrench software during diagnostic checks and reflashing. OPT
Old Apr 16, 2012 | 06:20 PM
Padraic's Avatar
Thanks, Ill leave it alone then.
MATT BOOTH
Technical and How-To Articles
Sep 22, 2015 08:35 PM
Hondamx751
Aug 13, 2015 01:06 AM
JoAnnS
Jul 23, 2015 02:18 PM
tweeder
Jul 5, 2015 01:57 PM
