Clicking noise - Brute 750 help
Old Apr 18, 2012 | 05:52 AM
PSU888's Avatar
Default Clicking noise - Brute 750 help
I have a 2006 Brute Force 750, when you turn the key there is a clicking in the front right (not sure what it is called) while turning it on and then turning it off.
Well I noticed when I ride in Low that I can here this same sound, I am not sure what it is and if it is suppose to do that while riding in Low (maybe it happens in High, I just can't here it)
Can anyone tell me what this is??
Old Apr 18, 2012 | 09:48 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Is your belt light on? Sometimes your auto belt indicator will click or buzz when turn key on....
Old Apr 18, 2012 | 10:32 PM
PSU888's Avatar
No, everything is working as usual...just noticed this recently...
Old May 9, 2012 | 04:07 PM
Hayashi's Avatar
If the noise suddenly appeared, it might be the belt Actuator dc motor starting to go bad but not bad enough to cause any trouble at this time.
The sound you are hearing is that - the potentiometer in the Actuator housing having the dc motor returning to home position. But due to wear and tear and dirt inside the housing/gears, the dc motor is having some difficulty turning. Remove the 3 screws to disassemble, they carefully remember how and where the small gears are positioned. Remove, clean, greased them and reassemble.
Old May 9, 2012 | 09:29 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
it's normal when you cycle the ign key- believe it mentions it in the owners manual. both my brutes did it also.
Old May 10, 2012 | 09:47 AM
Hayashi's Avatar
Since noticed just recently, something has changed.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
