help sportman 500 no power
wheeler runs like it has a 5 hp motor. it takes about a country mile to reach top speed. the odd thing is the problem is not constant. we checked the electrical and carb and cam. any ideas
Please don't double post in the general forum and the expert section also! If it takes a while to build up speed I would have the clutches,belt ,etc checked out first, IF you're sure the cam,carb,fuel supply has been eliminated. OPT
If you haven't pulled the recoil and checked the stator and pulse coil for mud,dirt,etc wouldn't take long to check this along with checking stator and pulse coil resistance specs. Don't hold me to it but the pulse coil white and white/red wires leading to the cdi should be around 97 ohms + or - 20% and the stator red and red/black OR red and green?? should ohm out at 446 ohms + or - 20% also. Plus have you made sure your fuel isn't water contaminated or old? Fresh fuel? Good fuel flow to carb? Clean air filter,etc??? OPT
i stopped in by my mech today. he says it does not seem to have a problem advancing. the spark seems fine. ant the clutch looks like new we thought the clutch might be shifting to early by we rulled that out
MeadowlarkFarm
Nov 27, 2019 08:40 PM
OPT
