06 Sportsman 700 won't idle
Old Apr 26, 2012 | 12:12 PM
Mike-3137's Avatar
Default 06 Sportsman 700 won't idle
I fixed almost all the many issues with my project quad, except for one....I've cleaned the carb...twice..but it still will not idle below 2000 rpm...It runs smoothly and pulls hard otherwise. I've removed all the jets and the pilot screw and cleaned every passage with a piece of fine wire and compressed air. Anybody have an idea of what I might be missing? Has anyone had this problem with a carbed sportsman? I think it has to be a blockage somewhere in the carb....
Old Apr 26, 2012 | 01:49 PM
Have you checked the intake manifold especially under the carb clamp for a split in the manifold? This could be sucking air and could be the cause of the idle problem. This is easily overlooked because most people don't remove the clamp and I've had several split there.Check this out first. OPT
Old Apr 26, 2012 | 03:15 PM
Mike-3137's Avatar
Thanks for the reply OPT, I did look briefly at the manifold when I last had the carb off, after seeing a previous post about them splitting, but did not think to remove the clamp, I will double check that area thoroughly again this afternoon. I will be a happy camper if that is the problem....
Old Apr 26, 2012 | 06:30 PM
Mike-3137's Avatar
Well its purring like a kitten now, but it wasn't the manifold or the pilot jet. After fiddling with both adjustments, and looking the manifold over I noticed the throttle cable seem to have some slop in it...I adjusted that, then readjusted the other jets at she settled down to a nice idle.
Now when my kits come in to rebuild the master cylinders, it may actually stop AND go....
Thanks for the help....
Old Apr 26, 2012 | 06:40 PM
Glad it was something simple OPT
Cole Hadden
Jun 15, 2025 09:05 AM
ghost civic
Jul 27, 2015 03:15 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
