2008 scrambler 500 HO bearings ,seal
Does anyone know the numbers of the bearings and seals on the front wheel of the 500 AWD. The polaris dealer says that all the bearings are the same as well as the two seals. I need the numbers of the inner bearings and seal. Thanks
The bearings and seal on that site are the ones that I have but I need the bearings and seal that go on the inside of those, the id of the bearings are larger to go over the splines and the od of the seal is smaller
Other members may have this info, plus the bearings will have a "universal" number on them that you can match up at any auto sore or bearing house. These are just regular Timken bearings. Seals might be a problem as far as matching them up,but you can try. I just used oem at our shop. OPT
