2010 sportsman 500 ho randomly dies
Old May 7, 2012 | 09:23 PM
jdc442's Avatar
Default 2010 sportsman 500 ho randomly dies
I have had a problem with the quad randomly quitting. There is no specific pattern to when it quits but it always starts right back up again. It never sputters or hesitates like it would be a carburetor problem (it did backfire one time) but I lose display which makes me think it may be electrical. I have tested the ETC by holding the cable and revving in neutral and it stops the engine like it should. I have also removed the pod and traced wires and vent tubes checking for kinks and shorts. Dealership can't replicate the problem of course. Any thoughts or ideas where to start checking? I do have the Clymer manual handy!
Old May 7, 2012 | 10:22 PM
user493's Avatar
Moto Psycho
When mine died at random a few times it was because the key ring was hitting the gas tank and turning the key just a little bit. I hope your problem is something simple like that.
Old May 8, 2012 | 05:46 AM
jdc442's Avatar
Thanks for the reply. Yes I have made sure there are no keychains and have noticed the key is still in the on position when it happens!
Old May 8, 2012 | 06:15 AM
Jaster94's Avatar
the experts will have to chime in, but i've heard that a voltage regulator can get too hot and it'd kill the engine until it cooled off. i don't know if that's possible, i'm no electrician. the last two polaris quads i had was like jumbofrank's issue, my key ring would barely tag the fuel cap and it was enough to kill it and the other one would die after running a while. when i heard that it could be the VR, i changed it out and it never had another issue. it worked for me that one time. . just check it out before you spend too much money. what worked for me may not work for you. sorry.
slowgsxr97
Mar 18, 2022 03:40 AM
Gtsordo
Jul 22, 2015 01:27 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 4, 2015 06:13 PM
