polaris problems
Old May 10, 2012 | 09:56 PM
cminer1969's Avatar
Default polaris problems
i bought a 2000 polaris 500 and when i bought it the drive belt had been replaced by dealer and now it wont go into any gear
Old May 11, 2012 | 12:05 AM
switzomatic's Avatar
Sounds like the buttons on the clutch might be bad.
Old May 11, 2012 | 06:50 AM
Steeves's Avatar
How many miles on the bike?
Old May 11, 2012 | 07:00 AM
If it's creeping in gear or hard to get in gear you may need to align clutches. If it wont shift into gear usually it's because belt is hitting the side of front clutch instead of the one way bearing causing rear clutch to turn. You might try to turn idle down first and see if it helps with shifting. OPT
Old May 11, 2012 | 07:16 AM
fmartin_gila's Avatar
Shortly after I first got mine, I found that I had to consiously ensure that I had removed all pressure off the throttle as I was just bringing up the RPM's enough to prevent a clean shift.
Fred
Old May 11, 2012 | 08:16 AM
Steeves's Avatar
How do you press the throttle and shift at the same time man. Aren't they both on the same side of the bike? Make sure the choke is fully in.
Old May 11, 2012 | 12:47 PM
cminer1969's Avatar
only 1100 bike wont move at all except when turned off u can roll it
Old May 11, 2012 | 12:50 PM
Can you put in gear or is the gearbox locked up?? OPT
Old Jun 12, 2012 | 08:58 PM
cminer1969's Avatar
Default broken down
the bike will operate in low range fine but when pu in high range or reverse its like its in neutral it does nothing
Old Jun 13, 2012 | 06:32 AM
Check the linkage arm (belcrank) on the transmission if you don't have high or reverse, could be the aluminum belcrank is stripped or loose on the transmission shaft and just turns. OPT
green giant
Jul 13, 2017 12:07 PM
DJS
Jun 28, 2015 11:34 AM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
hoopduerr
Jun 1, 2015 08:22 PM
