1995 scrambler scrambler 400 4x4
Old May 19, 2012 | 09:03 AM
6jeff6's Avatar
Default 1995 scrambler scrambler 400 4x4
What Carb kit do i order for this machine? Found a ton of 97 and ups but no 95. Is there something different on this Carb and while Im at it what kit do you guys recommend?
Thanks
Jeff
Old May 19, 2012 | 12:04 PM
Moose carb kits along with Sudco (you can order em at most shops or on ebay) come pretty complete with needle valves, jets, gasket,springs,o-rings,etc. Main difference between kits would be the jets.(may have one size smaller main and one size up on the pilot jet on the 97 kit) If it came down to it you could reuse your main jet and pilot jet if you had to. Plus most people don't replace the float arm and float pin that can wear out (doesn't come with most kits) which you can order through Cycle Parts Warehouse or Cheap Cycle Parts. OPT
Old May 19, 2012 | 05:00 PM
6jeff6's Avatar
Thank you. Im thinking needle and seat issue for me she just keeps dumping fuel out bottom hose with gas on. Must be sticking..
Old May 19, 2012 | 08:14 PM
You can just replace the needle and seat (needle valve assembly) and reuse the float bowl gasket etc,but if the float arm is wobbly back and forth,best to replace it and the float pin too. Adjust the float arm to where it's parallel with the carb body when held upside down with pressure on the float needle. OPT
Old May 19, 2012 | 09:22 PM
6jeff6's Avatar
Nice i will do that thank you.
exmotocrosser
Sep 13, 2019 06:12 AM
wendal
Oct 31, 2017 03:31 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
