Does your EPS do this?
Old Jun 1, 2012 | 03:34 PM
jefffoxsr's Avatar
Default Does your EPS do this?
When I turn the handlebarsl far left or far right the engine rpm raises quite a bit and the quad will move if you are stopped. There is plenty of freeplay in the throttle cable so that's not the cause.
Does your sportmsan do this?
Thanks.
Old Jun 1, 2012 | 06:10 PM
TheATVSuperStore.com's Avatar
Former Sponsor
None of my units do that.
Old Jun 1, 2012 | 06:20 PM
You can have free play at the throttle housing but as you turn the bars the cable itself down lower can be moving altering idle. Might want to check the cable routing out. OPT
Old Jun 2, 2012 | 08:26 AM
Specta's Avatar
I have not experienced that with either Touring EPS
